RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.20.2006, 10:04 AM
Originally Posted by DarcyRou
Have a few problems with my brushless set-up. I have an MGM 120 controller, fiegao 8xl, ubec, 4s 8000mah lipo pack.
Problem #1 If throttle epa is at 100% when I nail it off the line it will cut out until I let off throttle
Problem #2 After running for a few minutes the mgm will have a dim light on all the time and will do nothing, after 30 minutes of being diconnected it will come back to life.
any suggestions?????
Thanks
Problem 1 sounds almost certainly like low voltage. I would give Serum's suggestion a try. Also, after you go through the programming sequence, did you do the autotuning? This is an important part of the programming(some settings won't take if not performed). Was the throttle EPA at 100% when you programmed the controller?
Are you using a UBEC or receiver pack? If so, did you disable the controller's BEC?
Also, what settings did you actually program into the controller? Perhaps we can discuss some of these and figure out how to get you going.
