MetalMan
MetalMan's Avatar
10.20.2006, 05:47 PM
Does the balancer go between the battery and charger? If it does, does the balancer have an extra set of wires coming from it that attach to the battery's output wires? If it doesn't have the extra wires, and does to between the charger and battery, then 3amps is the max. you should do. Otherwise, charge as high as you want! (1C max. recommended, of course).
