jagboy
jagboy's Avatar
11.01.2006, 07:34 PM
I've actually updated it in two other forums. I didn't think anyone here was very interested in it. I'll make sure to keep you guys up to date from now on. Here's the update:
I eliminated the need for a solid gearbox by adding individual axle mounts. I also stuck another gear in there for massive reduction. I've been having problems with overdefinition all weekend so I didn't get the pusrods in, the left TVP has a couple errors, the steering system is reworked but not completed, and the a arms aren't quite right yet. All in all this project is rapidly nearing completion. What I still have to do: wings, the belt, gear teath, the brake system, all of the fastners, weight shedding, and a final render. I was tempted to put a render in this post but I thought it would be a bit premature. Expect one within the next two weeks but hopefully within a week. The renders look amazing by the way.
JB
PS: Harm Racing and FG Modellsport also have 1:5 scale F1 Cars. In fact, my car may seem in many respects very similar because in some aspects it is. The front suspension is very different because it has standup shocks and the arms are attached to a chassis plate that is mostly inside of the body as opposed to Harm's and FG's being attached to a chassis plate that is in turn attached to an extended base chassis. This gives the car a much more realistic look. I am sure my differential is different too as I designed it. For me, though, the most important difference is the realism. I designed the body as per 2008 FIA F1 technical regulations paying close attention to every part to make it look real. The tires and wheels are also 1:5 regulation size (FG tire internal diameter gets larger near the body) and the ride hight is scaled as well. Admittedly, I almost always have both websites up when designing to see how they did certain things, but I constantly strive for innovation and improvement.
