squeeforever
squeeforever's Avatar
11.04.2006, 04:36 PM
Ok, on the Apache, there is a lead for the power supply, its the ones with aligator clips and there is a battery lead with some sort of plug on it. Put your Deans, Powerpole, etc. on there and charge through that using a Y harness. Be sure to set the jumpers to 2500mah and 4S. Also, the balancer(s) hook to the taps of the batteries. I'm not sure what your talking about with the wires, but chances are you either need to buy an adapter (should have come with them) or you need to make an adapter. Its not really hard, but I need to know what balancer(s) your using...
