nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.06.2006, 09:57 PM
Originally Posted by nbcaznmaster
nope, but i think i got teh charger working, the red light was on! BUT! they said that the error/chk will be green when fully ballanced and charge. which is what happened on the balencer. The apahce on the other hand still says its charging... Odd thing is that the the direction where it said its full charged, is right before the direction which says, than connect to teh charger and begin charge..... So i dont know if it means my pack was balenced and was still in middle of charge or that it was balanced and charged. charge time was about an hour or so if i went by the balencer.
Hmm i just heard that you do not need to balence all the tiem. That its only occasionally. Is that true? If thats true then it makes sense that the balencer doesnt help the pack charge, it only helps stabalize so then you remove the balenver adn then allow it to charge directily. But im hearing diff stuff from you guys.
  Send a message via AIM to nbcaznmaster
