Thread: Batts.
11.06.2006, 11:48 PM
No modification is needed. You plug the input of the LBA10 into the charger, then the battery's main power and the balancer connectors into the other end of the LBA10.
The only time it may get complex if you decide to use and charge two packs at once. This requires a Y adaptor for the power and the balancer. If you are using one pack, it's quite simple.
By the way, which Superbrain are you planning to get? There might be better and maybe cheaper solutions...
