Dafni
Dafni's Avatar
11.07.2006, 03:21 AM
Hi Dale, welcome to the Forum!
As for bulletproof trannies, the only thing you'll need are the steel idlers from this site. Single speed or not is your choice. Even the two-speed tranny is hard to kill once you have the steel idlers.
Another trick is to reinforce the pins that hold the gears on the input shaft. I use a small nail or bodyclip.
These two things, and your tranny should be ready for some serious BL power.
And stay away from the Traxxas lightweight shafts.
Good Luck
Daf
