vette1
vette1
vette1's Avatar
11.07.2006, 09:12 AM
Originally Posted by cemetery gates
i had to fit a ofna 51 spur to a RRP slipper plate once.
i dont have pics, but i had to press the plate onto the spur with a bench vice (there is an indentationin the spur)very carefully because it is a tight fit. after i just drilled new holes in the spur. it came out perfictly round............
maybe this will help
I tried what you said and boy what a project. It works ok but it does wobble a little. Also, I put a flat spot on the motor and I had a problem getting the pinion on. Finally made it on after having multiple problems and not the pinion is a little wobblely also. I have to see if I can get the flat spot more even so it will be perfectly flat. Than maybe I will not have the problem anymore.
I'm getting my strobe slipper parts and Monter GT parts tommorrow in the mail, Mike is sending out the rest of the stuff that I need today so I will not have to worry about the slipper anymore. However does anybody have advice to make the metal shaft that comes out of the motor perfectly flat so that I do not have a wobbleling pinion anymore?
I'm crazy and I'm not afraid to talk about it.
