11.07.2006, 11:53 AM
If you go 8xl on 14 cells and gear it up, you can hit 40's as finnster said, anything faster would require more cells or lipo if room is an issue.
Batteries determine a lot with BL, the better the batt, the faster you go. Of course, it also depends on motor. But if you have crappy batts, then the rest is worthless. That's like running water in your gas tank with nitro.
