11.08.2006, 02:16 AM
Are you charging through the Spektrum's charging jack? If so, don't. It doesn't seem to work so well because I had issues too. There must be other circuitry in there. Remove the pack from the radio and you will see the "9v" connector on the end. Use clips or something and charge from there.
