Thread: which pinion
MetalMan
MetalMan's Avatar
11.12.2006, 07:36 PM
As long as you have a mount that won't flex and your gear mesh is correct, the plastic spur will NOT strip. Besides, it's more likely that you would shred the hardened pinion gear than strip the plastic spur gear, and the pinion costs A LOT more to replace than the spur gear.
