Finnster
KillaHurtz
Finnster's Avatar
11.14.2006, 12:32 PM
Originally Posted by riceman
Thanks for posting up those vids. Did you do any special proramming of the Mamba Max? I've tried out different battery combinations myself. My LST2 conversion does fine with 4s 8000mah and also with 5s 4000mah. However it is not too happy with 5s 8000mah. With the 5s 8Ah it will run only if I ease the throttle up but once it reaches half throttle it shuts down. I haven't quite figured that one out yet.
Hmm that is odd. My MMax is actually stock from the box. My comp is having a little meltdown w/ the usbs and I've never had a chance to program it. I could do some manually, but.. been having too much fun to bother.
Besides myself and Cart123, you are the only other I've heard to run 5S yet, so its very much R&D at this point. Did you but in a voltage cutoff? My only thought is that perhaps with your large truck and big 1515 Neu motor you end up pulling a lot more amps and lose voltage below the cutoff. Or its just too much for the esc... I would think the 8Ah batts would be better as far as voltage drop, but maybe they are lower C batts vs the 4000s and don't handle the lg load as well. Perhaps its even a bum cell in the 8Ah pack... :032:
Cart123 actually ran more voltage (6S M1 cells) but really only had thermal issues IIRC, so I don't know if its raw voltage. We're playing on the edge of the edge w/ the equipment, so there are no guarantees. Very nice conversion tho, drives great.
