11.15.2006, 11:13 AM
While #1 and #3 are common sensorless symptoms, I have NEVER seen that happen with my Quark 125.
Is maybe #2 because of the relatively large motor you have on there? I know it technically works, but the MM was never designed to be used for 1/8 scale apps with large motors. It would be nice if CC could fix this though as the MM can obviously handle the load for the most part.
Here's a thought; does #2 have anything to do with the use of a 4 pole motor? Maybe try a regualr 2 pole, like a Wanderer as a test. After all, it's only $90. A 7XL or 8XL should approximate the Neu you are running pretty well. Of course there will be differences, but it's just a test.
