cemetery gates
11.15.2006, 10:37 PM
Originally Posted by overtki11
hey guys,
i'm thinking of getting them FLM hybrid bulks that use 1/8 diffs for my emaxx....would the diffs from a hyper 7 fit? and also will the ratio be the same as my stock maxx diffs? or would i need to gear up or down on pinion tooth count?
i'm not using insane BL power..just the regular HV....so i figure the 1/8 diffs would laugh at the power put out by 4400 motor...haha.
initially though of just getting reg alu bulkheads to replace the stock plastic ones, but i know that my stock maxx diffs will die eventually, so buying a hopup alu diff and alu bulkheads and alu diff cases starts to add up....i can get a pair of 1/8 diffs fairly cheap thats why i'm considering the hybrid bulks...
any words of advice before i click "add to cart"?
Well, i am not sure if the Hyper 7 diffs will fit, most likely they will. I know the ratio of them is 3.31:1 as where stock maxx is 2.85:1. You will have to use a larger pinion to compensate...........
Bye:018:
