GriffinRU
11.18.2006, 08:52 PM
Originally Posted by sleebus.jones
Well, it seems to defy the laws of physics at first glance. The amp draw goes up as the battery voltage goes up...that doesn't make sense. All things being equal, higher voltage should equal less amp draw.
Also, the back-calculated Kv rating varies with voltage, another weird thing:
1. 3S = 1306Kv
2. 4S = 1250Kv
3. 5S = 1281Kv
4. 12v = 1320Kv
Something's not right, or someone's being sloppy.
Sleebus
I was more intrigued with motor mount; math might work if you take efficiency into consideration and power constant.
Artur
