jagboy
jagboy's Avatar
11.19.2006, 11:47 AM
Mass properties of la_car ( Assembly Configuration - Default )
Output coordinate System: -- default --
One or more components have assigned mass properties:
3060@chs_mountedmotor@la_rearend
standard_ma4s2p8000@la_rearend
standard_schulze40160@la_rearend
Mass = 13521.21 grams
Volume = 7830216.84 cubic millimeters
Surface area = 2785076.50 square millimeters
Center of mass: ( millimeters )
X = -27.27
Y = 64.34
Z = 387.53
So, the weight is 13.5 kilos. It's a bit on the heavy side, but seeing as the HARM is, I think, 12 kilos and this one is probably much more powerful it shouldn't be a problem. The electronics are heavy: motor is 1.2 kilos, the batteries are .725 kilos a piece and the ESC is 210 grams. If this was ever to be produced I'd have to cut the weight down a little bit, but it's in the general area I want it to be in.
JB
