11.19.2006, 05:37 PM
The bearings aren't the problem. Your asking for trouble when you put 3s on one of the highest amp drawing 540 motors out there. It's worse than putting 3s on a cm7700, which has been done with costly results. The mamba max esc would shut down constantly. Don't confuse the feigao 540 motors with the mamba max motors. The mamba motors are much tamer, meaning they draw less amps per kv, similar to what a 380 motor would draw.
You will be better off running 3s with a cm5700 motor.
