Thread: New Revo Owner
MetalMan
MetalMan's Avatar
11.19.2006, 07:08 PM
Originally Posted by BrianG
Very nice! Mike ought to make something like that for the Revo crowd! Are you going to come up with some type of cover for the gears? Probably not needed, but you never know about those stray pebbles/rocks and that's a lot of gear exposed...
By the way, where did that extra chassis piece come from? It's the one in this pic, right under the motor wires...
There will be a cover for the gears, and it most likely will be 1/8" thick (clear) polycarbonate, bent to shape using a flame. There will also be some sort of guard under the diff gear, but I haven't figured that one out yet.
I'm not sure where the "extra" chassis piece came from. I have done very little to the chassis. Maybe it's like that because it's not a Traxxas chassis, but an extended one that came out before the 3.3 chassis?
Originally Posted by Dafni
Nice slipperential rip-off ;)
When you trim those fins off the slipper plate, you can get the spur closer to your mount, and the revo input shaft deeper into the bearing. Just a thought :010:
Nice dimensions on this revo, Metalman. The wheelbase looks just right!
DAF
Technically it's not a ripoff because Mike hasn't made for the stock Revo chassis yet :027:. Maybe if Mike does make one for the stock chassis his will be a ripoff of mine :005:.
Good idea for trimming the fins off of the slipper plate! I never would have thought of that... As it is the input shaft is only in the bearing about 1mm, so this should add another 1mm of shaft into the bearing.
Thanks for the comments, guys! :004:
