rchippie
rchippie's Avatar
11.25.2006, 09:12 PM
I'm getting ready to hook up my UBEC to my MAMBA MAXX speed control. My ? is the manuel that came with the ubec says theres two ways i can hook it up. The first way hook it to the (input power source) then plug it into the reciver, this way the system will be hot when i hook up the power source. The second way is to hook it up to the (input power source) then hook up a inline switch then plug it into the reciver. The way i was going to hook it up is solder it to the power wires at the circut board then plug it into the reciver. So if i hook it up my way will the ubec still be hot when the power is hooked up or will the switch from the speedo cut the power to the ubec when it's in the off postion ?.
REAL MEN RUN BRUSHLESS
