B15
11.27.2006, 04:07 PM
I had driven the same set up many times before, minus the LVC. The motor couldnt have caused the LVC to die.
I should mention my truck is quite a bit lighter than a stock emaxx. I have a fibreglass chassis and mostly plastic parts, and I use 1/8 buggy wheels and tires. The 8l on 4s 4000mah max amps lipos (rated 60 amps continuous) has worked for me for a while. If I can get this LVC fixed Im going to try a 8 or 9xl on 6s next.
