zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.28.2006, 05:51 PM
Hmmm, maybe the aluminum slab is for durability reasons maybe? Instead of having the FET's right up at the case...
I also checked the FET, from what i can see the FET's are Infineon made, and are rated at 30V, and 100A capability each... thats the page i found anyways.
I wonder when ESC makers will utilize heat pipes to dissipate the heat, VERY effective, and makes for a lot of options as far as setup.
Do you think i will be okay with running 5s2p A123 cells with a 7.5 lb 1/8 emaxx buggy conversion, as far as thermals go?
