zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.30.2006, 06:27 PM
BrianG, so i popped off the power input end of the Quark and looked inside, pretty neat looking for sure. So did you say you would need a 3mm slab of Alum./Copper if I replace the two thermal pads/slab? What is actually holding the whole circuit to the case? Is it purely the thermal pads there? If i were to do this, i would be persuaded to completely seal the ESC right up to make it basically waterproof, and keep dirt out.
If i were to just attach the Quark to an upper aluminum chassis brace that would have alot of thermal mass and heat dissipation capabilities, would i even have to bother with making the thermal adhesive mod? Because there would still be a large temperature differential between the transistor surface and the outside of the case. I like to make things the best i possibly can, and quality is my name. ;)
Would you have any suggestions for using to seal all the holes in the ESC that is not conductive and that is thick applying, such as Silicone Caulking? I think this would work too.
Cheers
