B15
11.30.2006, 08:41 PM
Originally Posted by sjcrss
Im not saying you did this wrong or anything, but you are able to plug the wires from the esc into the plug in the wrong order...this is how the wires should line up from the esc to the lipo saver....and yes you can switch the plug around and still plug it in..cause I tried it with mine....
.............| Brown wire (plug) black wire... |...............
From Esc | Red wire (plug) Red wire ........| to lipo saver
.............| Orange wire (plug) White wire .|................
OK, I thought the plug was shaped to not allow that, but it definitly wasnt reversed. My steering servo was still plugged into the receiver from the last time I ran it, and I matched the wire colors with that, and I matched the esc wire colors to the LVCs colors.
Originally Posted by MetalMan
Are you using the 9920's internal BEC, an external BEC, or a receiver pack?
Im using a UBEC.
Right now Im pretty sure the LVC was defective.
