zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.01.2006, 02:25 AM
Hey, just to add, it appears once i took a closer look, that the slab attached to the case is only touching on the edges, it's not even touching in the middle...
Yes i was planning on using Alumina.
Do you think this mod is necessary for a 1/8 emaxx buggy? It will weight in at about 7.5 lbs. What do you think?
