neweuser
neweuser's Avatar
12.01.2006, 12:30 PM
Originally Posted by BrianG
The use of a segmented system reduces magnetic flux "eddy" currents, which are losses. Instead of having large eddy currents in a solid core, you have a bunch of much smaller ones, which apparently is better. Which is the same reason pwer transformers use many plates instead of a solid core. This page explains it.
Using segmented system may also have something to do with reducing hysteresis, but not quite sure on that. It's been a LOONG time since I was in shcool studying magnetic theory.
From my understanding, having more segments would create better efficiency and less resistance with better flow of "eddy" currents. the more segments that are used, the better the conductivity creating less loss? Did I understand that right?
