12.01.2006, 05:29 PM
Glad to hear its working well for you. I had the same problem w/ mine on the brakes. You can just turn down brake power (as mentioned) or go into castle link and redraw the brake curve to make it more progressive, as well as a bunch of other tweaks. Same for the throttle as well, help tame the beast a bit and make it more drivable. Before I was flipping either forwards or backwords w/ too much finger action.
The usb setup is really slick. Post a top speed if you can, I'd like to compare it to the 8xl.
