GriffinRU
12.03.2006, 02:52 PM
Originally Posted by Serum
Sorry, my bad. it does 6100 joule. (6100 watts in bursts)
total amount of energy is 532800 joule.
I personally don't see the advantage of these cells, their internal resistance is too high, and with the right cells (read good quality) you wouldn't need them (which was my point) they would add nothing but weight.
Once they reached a lower internal resistance they will be more interesting in replacing batteries, with the ability of very quick charging.
This cells will never replace batteries. They will boost batteries performance and replace them in applications with short-term power requirements.
Tens of mOhms is pretty low, not every battery can have it.
Self-discharge rate kill them as batteries
Charge-Discharge cycles rating put them ahead of batteries
Also wider operational temperature range...
Artur
