BP-Revo
BMW M Power!
BP-Revo's Avatar
12.07.2006, 01:59 AM
Originally Posted by Cheater
Shooting me down because Novak rated a speedo at 700 amps is not very constructive.
I wasn't "shooting you down," just simply using a sledge hammer. :018: Just kidding lol :005:
I was just agreeing with the post before my (Serum's) that stated 25amps is too little for a 1/10 scale...
I was just pointing out the vastly high amp rating on a popular brand of 1/10 scale speeds controls (even though it is brushed).
However, it seems like you have given this considerable thought and have calculated it down...so I guess it's worth a try. A mamba ESC is only like 80 bucks in the end, so its not exactly a wallet buster, but its not something I would recommend.
I would like to point out one thing. On the CC website, I read somewhere that using the M25 ESC on 3S Lipo with the 8000kv motor voids the warranty...while with the MM it says you are not supposed to use 3S on the 7700kv because the RPM would be too high for the motor, but the ESC is fine. So, I'm not sure you can overtax a M25 like you can a MM...
It seems to me an MM has much more research put into it than the M25, because (supposedly, from what I have heard) the M25 coggs a bit at startup with the 8000kv motor, but the MM doesn't cog at all with any motor...
Well, whether you decide to do it or not, good luck...
*cocks gun...takes aim* lol...couldn't resist...
