12.07.2006, 05:39 PM
I'd say the 2s2p pack will probably have less resistance since you are doubling the contact area. But then again, you are doubling the solder joints.
And then the point about balancing is valid too.
Personally, I'd go with the pack that will fit in the space you have with the amp and Ah rating you need/want. If they are both the same size and ratings, go with the cheaper one. :027:
