Serum
Serum's Avatar
12.09.2006, 02:02 PM
The total current will go thru the motor. you mean per phase? I guess that would depend on the poles of the rotor..
I heard something about the Y and D winded Neu motors, what i heard is that the differences are not noticeable
it's just easier to wind and compress that way, and probably more durable during compression.
well, the main reason is that thick round wires leave an awful lot of space (air) between the different wires. this would result in a less efficient motor.
That's the main reason. the fact that it's easier put in place (more flexible) is a nice feature that comes with it.
Do you know how many 'separate' wires there are?
no, you can't tell. That depends on the current the motor needs to take, and the amount of winds it has. The less winds (higher KV), the more wires 1 phase will be made of.
The more winds a motor has, the thinner the input wires are. (and this is possible, because the motor is made for a higher voltage, so the current going thru it will be lower as well. (proportionally the other way around to reach the same power)
