zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.09.2006, 08:57 PM
Do you mean motor starting capacitors? Like that have a relay to disconnect when up to speed?
Has anyone heard of the Halbach array? It's magnetic sequence where each subsequent magnetic is turn 90' from the next, and this cancels the field on one side of the array, and magnifies it on the other side. A small company (couple guys) made a BL motor for solar races and it used Halbach array, the motor had a full load efficiency of 98%. WOW.
Also, can someone explain the Neu motor codes... like what does 1515 1/Y mean?
