Serum
Serum's Avatar
12.10.2006, 05:03 AM
It would be near impossible to use square wires in a motor. The routing would be a PITA, especialy thru corners. also; square wire is more sensitive for damage than round wires (on the angles the isolation will be thinner, and these angles make the windings easely shorted when pressed together.
With speakers it's fair easy to use square wire; the voicecoil is round, routing the wire straight is easy.
Yes Brian, Y stands for Wye and D for Delta winded.
