Batfish
Batfish's Avatar
05.30.2005, 10:12 AM
Originally posted by lipomax
I don't understand why your motor is running so hot. I run my Basic 5300 with a 17 tooth pinion and even with 11.1 volts, it doesn't run very hot. The controller gets about 190 degrees F and batteries are around 110 and motor is only about 150. I'm flying too.
I definitely don't want my controller getting to 190 since the MGM is set to thermal at 194, according to their manual. Also, according to their manual, if the controller is over 158 (and off) it won't turn back on until the temp is below 158. This means that I probably wouldn't be able to change a battery pack during a race unless I left the controller on. I don't want to be in that boat. I don't expect that I'll HAVE to change a battery during a race, but I can't rule that possibility out. If a battery dumps before the 15 minutes are up, I'd rather lose 1 min of the race swapping a pack than not finish at all.
What vehicle are you running that setup in, lipomax?
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
