Thread: baja 5b bl
Serum
Serum's Avatar
12.19.2006, 12:43 PM
Zero; a 1950 would do well. it's not about the size it's about the weight. you can take a 1950 and use 10S on it. it will do 45 mph with ease. and i doubt if it will get any hotter than a 2240/50 The 1950 is capable of quite something.
I have had the 2250 and now i have the 1950. i like the 1950 better. like i said; it's 2wd and you don't want too much torque on a 2wd.. there is a difference between uncontrolable and uncontrolable. a 45mph can be harder to control than a 60 mph truck. again; too much torque on a 2wd will be a horror to drive. i had a 7 kg heavy savage powered with only 16 cells. and it has pretty good torque. (uncontrolable on a 4wd already, leave alone a 2wd with about the same weight..)
