12.19.2006, 06:46 PM
Hop-ups...Just a few things you can consider:
Racers Edge aluminum shock ends
8mm axle conversion (I can give you all the part # if your interested in this)
If not 8mm axle conversion, I would at least put CVD's all around (rear has dogbones).
Edit RC aluminum parts (almost, if not all of them)
HB GTX front and rear diff cases. There a direct replacement and a hell of a lot stronger...
Buggy upper arm mod (again, I can give you the part # if you are interested)
Shock socks are nice :D.
That should be about it. I have done most of that to mine and all of it was easy. I have yet to do the GTX diff cases and the Edit RC parts, but that will come soon :D.
