crazyjr
crazyjr's Avatar
12.20.2006, 09:34 PM
Originally Posted by Dafni
crazyjr, in comparison to what phildogg got, what temps do you get on your MM/9XL?? (if you run 4S, that is. Not sure if you still run Ni)
So far i have been hard on it trying to get it to heat up(stop and go, lots of brakes, running on blacktop to strain it) I haven't got it over 139* the 9xl is running about 120 in the same circumstances. This is with a set of 8000mah maxamps lipo's ( new 20c type) and it rips, literally, I tore up the rear diff trying to make it sweat. So i think it will make a good racing setup for mid to short tracks, going to try taller gearing to get some speed
