neweuser
neweuser's Avatar
12.21.2006, 04:19 PM
Originally Posted by crazyjr
On one, no i'm not at this time. On two, I had to go with a strobe and 51 tooth mod1 with a 13 tooth pinion, it seems ok on dirt but a little slow on pavement. And for your last question, I'm running default except for a 3v per cell cut-off for the lipo.
Neweuser, If you want ultimate power and run high voltage, the mamba max is not for you, however if you want a reliable, consistent at 4s lipo and easy to use esc for racing, the mamba is probably the ultimate esc for the job.
I agree....:027:
