squeeforever
squeeforever's Avatar
12.21.2006, 10:41 PM
I will be running slipperential
Maybe this helps...:005:
I did a little figuring and with the 7XL, 4S LiPo (3.7v per cell), buggy diffs, and the slipperential geared 20/36, I came out with about 40 mph. That is about right....Isn't the reason your not going with the buggy diffs the fact that you couldn't gear it high enough? Well, I think you can....Not sure, but I'm pretty sure that 20/36 is possible with the slipperential. It should allow enough adjustment...Even then, I think you could manage to get Mike to get you a 22T pinion. I know for a fact that he can get a 24T but you shouldn't need a pinion that big. Anwho, 16/36 should be about right if you don't go with the buggy diffs...
