neweuser
neweuser's Avatar
12.22.2006, 02:52 PM
Originally Posted by squeeforever
The biggest spur for the Revo is a 40T. Also, why would you want a 44T? Thats to big...Your gonna need to go as small as possible on the spur and probably as big as possible on the pinion if you go with the Slipperential...Anywho, I would go with the buggy diffs, a 7XL, 4S LiPo, and somewhere around a 18T pinion. You should get around 39 mph without the tires ballooning (if the tires balloon slightly, you will gain a mph or two...). With a 20T, somewhere around 43...That should be about right...
Why? Because as I said, I do not know the Revo slipper and what it takes and would hope you would chime in! LOL, also, henever specified what this is going into? Anywho, I was thinking the 36 would be too small and the gearing would be too high....
