12.22.2006, 03:23 PM
squee how does it sound does it sound like every thing will work efficiently with no heat issues as far as the stuff you mentiioned the reason i have the integy shocks is because they are free and i figured i will use them at least untill they break and then get power strokes, but i think it is usless to get them for free and just not use them. I know they are not as good but mitaswell usethem if they are givin to you for free at least untill they break. As for the flextek arms i already have them and i got them off of ebay so i paid about half of what they are worth so i guess thay was a good deal. I did not know you cant use sliders with the diffs so yes i will change that. As for the crime fighters i will change that to i did not know there was one with ribs on the inside. The thing i wanted to ask you is about the motor and esc do you think i will be able to run not overheating/and efficient when using the 18t pinion and 36t spur. Basically will it all work efficiently once i fix those minior things you requested. Thanks
