Thread: gearing?
maxxdude1234
maxxdude1234's Avatar
06.02.2005, 05:42 AM
I would start low and work your way up. If you're running a 66t spur gear , personally, I would start no higher than a 16t pinion. It does depend on the amount of cells you use and the weight of your truck, and I'm sure someone else on here would be able to give you a more accurate figure....All I will say is start low and work up.
