cant fig. out how this works
drkros3
cant fig. out how this works - 01.03.2007, 03:26 PM
ok i about to build a brushless emaxx. but i cant figure out how to use the dual batterys with the speed controller i want to use.
i was goign to use a mamba max 5400kv with 2 3cell 4000mah lipos
but the speedcontorler one has one battery plug coming off of it.
now do i splite it into two plugs or how do i do it?
thanks
the reason for using the mamba max was cause i can get it for so cheap cause i work at hobbypeople.
also do you think the mamba max will give the car that much power? or should i up it to something else
