Well, I'm almost done with the project. I've tested the drivetrain and everything works perfect! There is only one issue, thus far...I had to use a 32P 18T pinion and a Kimbrough 68T Spur, instead of the new Strobe Slipper Clutch that I was hoping to use, because the gears would not mesh. The case of the Plett hits on the transmission housing before the gears can fully mesh. Here is a thread that I started, to discuss that issue:
Strobe Slipper Question
I will run it tomorrow and post pics.:)
