jhautz
jhautz's Avatar
01.05.2007, 08:18 PM
Originally Posted by remie
is it possible to use 4mm connectors?
because I've got those laying around.
Yes you can use 4mm connectors on your 9xl and 9920 if thats what you have. They should be fine.
I never had a problem with the 4mms. technically the 5.5 connectors will handle more amps but the 4mm never heated up or anything when I used them so they were fine.
I used 4mm for a while and then switched to the 5.5 only because the Quark came with 5.5 and it was a pain having some motors/controlers using 5.5 and some using 4mm. So I switched all of them to the 5.5s. Now I can swap motors from vehicle to vehicle with no hassles. Just plug and play.
to make it...
or break it...
Silent...But Deadly
