MetalMan
MetalMan's Avatar
01.08.2007, 12:18 AM
1. 2. You will need to reprogram the ESC. Check here for instructions. Also be sure to try reversing the throttle channel, as that could cause the ESC to not be programmed properly.
3. That's normal. It does that because the capacitors charge up very fast.
BTW, where is Seaside?
