GorillaMaxx360
GorillaMaxx360's Avatar
01.09.2007, 07:26 PM
Originally Posted by neweuser
I went trough all the stock idlers on 3 runs or so. But I was bashin pretty hard. Even stripped a second gear clean smooth. went to the single speed and same thing, plus broke the wimpy pin that holds the gear on the top shaft several times.
Cut a hex wrench as a pin they are strong. or pic up a stronger slightly bigger pin and freeze the pin and put the top shaft in the overn the pin will shrink(or it is the other way around) and the shaft hole will get biger slide the pin and when they cool back down the pin will expand and the gear hole will shrink assuring that the pin will never come out. Of course i am not familiar with the top shaft so this may not be necessary or they might sell and aftermarket pin.
