revopqrs
uhhh-huh!
revopqrs's Avatar
01.10.2007, 05:13 PM
well i just snagged another set of ofna 12mm shocks, so ofna it is!! i just did some test fitting with the ones i have on the stock towers.... it looks like the front ofnas will be a direct fit, the rears are too long. but with different towers i think the rears would work just fine. theyre about 3/4" longer than the fronts. the fronts are 1/8" longer than the stock maxx shocks.
i ended up using rear springs on the front shocks to get a little more preload.
