cemetery gates
01.10.2007, 05:28 PM
Originally Posted by squeeforever
http://www.lstshop.co.uk/catalog/ind...7ae9b7702ef386
http://www.truggyracers.com/forum/in...p?showtopic=45
Let me know if you need the 8mm axle conversion kit parts...
Heres the parts for the upper arm mod:
22* hubs
buggy arms
upper arm pins
balls for rod ends
you can use these (the things on the far left and right sides, they should have came with your truck) or I would recommend these instead.
I would also go with this to eliminate some flex.
Thanks!
Bye:018:
