Thread: evx and lipo
turbo4
turbo4's Avatar
01.14.2007, 06:48 PM
Dropping a tooth on pinion is not hard. You would loose maybe a mph or 2.
The torque you gain is alot better though. Seems like the motors run cooler
as well though. Cooler motors make them last longer.
IF the brushes are bad in the motors the power will suck.
Sounds like what I might try, dropping a pinion tooth or 2. How do I adjust the slipper? Is it possible the brushes could be bad, I just got it outta the box with only 10 minutes of driving total?
