06.13.2005, 08:23 PM
If you have a gear locked out(and an empty spot in your receiver due to the missing servo), you could plug a 5 volt fan into the receiver with no trouble at all. You could also wire a fan to the existing fan with no trouble. If you are thermalling, you may try to gear down a tooth as well.
